stealth ram install questions?
Old Dec 9, 2008 | 04:53 PM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
ok i have replaced my lb9 with a l98 recently...so i wanna put a HSR on it...but is there any thing that i have to change .... ( i know fuel lines) and adjustable feul pressure Reg...should i change my fuel pump...i have the remote coil dist...is there anything else i am missing? thx
it is a 89(engine also from 89)
3.73s
headers
Old Dec 10, 2008 | 04:36 PM
RedHawkLB9's Avatar
Car: 89 Formy
Transmission: A4
Re: stealth ram install questions?
nobody has anything to say?
Old Dec 10, 2008 | 04:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The part information says you need a 58mm or LT1 TB.
Old Dec 10, 2008 | 04:59 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
is the motor modded at all? fuel pump only if your stock pump is failing or is very old. new walbro 255 is a nice unit for up to 500hp or so.
Other than that, you wont have to change anything other than what you have mentioned. stock L98 TB works just fine but may need clearancing onthe brackets to clear the fuel rail
Old Dec 10, 2008 | 06:02 PM
RedHawkLB9's Avatar
Car: 89 Formy
Transmission: A4
wich brackets.. please explain thank you
Old Dec 10, 2008 | 11:06 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
the throttle cable bracket. the big C shaped bracket on the throttle body where the gas pedal hooks to. you probly will need to cut off some of the end of that bracket to clear the fuel rail.
Old Dec 11, 2008 | 04:11 PM
RedHawkLB9's Avatar
Car: 89 Formy
Transmission: A4
oh man...youve been great help thx bro
Old Dec 11, 2008 | 04:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
some aftermarket TB's wont have that problem. Also there are two different linkages for stock thirdgens, and i know the 89 up one does hit the fuel rail fittings that holley supplies if you install the fuel rail kit like holley recommends. Old style i have no idea.
My holley 58mm clears great tho
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
