Intake manifold gasket?
Old Dec 9, 2008 | 08:49 PM
mr_blahblah3's Avatar
Car: 1989 Camaro z28
Engine: 5.7 350
I did a full engine rebuild and now I'm putting the intake manifold on. only problem is that I looked at the gasket and saw that there were only two cooling ports open, in the front of each side. So being the genius I am I cut about a 3/4 inch hole in the two back passages to let coolant through to the rear of the heads, because that's what an intake manifold gasket is supposed to look like right? (lol). A friend of mine told me that those passages are supposed to be closed so that the coolant is forced into the outlet in the back of the manifold. Do I need to put new gaskets on or will it be fine with the back ports open?
Old Dec 10, 2008 | 12:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It'll be fine. Some intake gaskets have them open, some closed. But, most intakes are blocked off back there, so it doesn't matter either way.
Bubbajones_ya
Aug 31, 2015 12:02 PM
earlpote
Aug 28, 2015 10:42 AM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
