Speedo weirdness
Old Dec 12, 2008 | 08:38 AM
Hubbardj6's Avatar
Car: 1984 Z28
Engine: 355
Axle/Gears: stock
Speedo weirdness
almost every time i get goin past 85-90 my speedo will make a strange grinding sound and sway anywhere between 20 to 120 mph. once i start to slow down it goes away. i asked my dad and he said that its pretty normal for that to happen when its worn out. If so, could i get some directions on how to fix or replace?
Old Dec 12, 2008 | 08:59 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: Speedo weirdness
Sounds like your speedo cable might need to be lubed. Take the dash apart to gain access to where the cable screws into the cluster. This will get you access to the cable itself. You should then be able to spray some lubricant down the cable. Don't use WD-40 though. Use a graphite based lubricant. That is where I would start anyway.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
