What should a vac. gauge read?
Old Dec 12, 2008 | 06:48 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Ok so i got a vac gauge to help diagnose my current problem also a air/fuel ratio gauge. i know how to install the air/fuel, but where do i hook the vac gauge to? and when it is installed what should i be looking for through out the rpm range?
Edit: I installed the gauge into the hose going to the stock air lid. It read 24-26 Hg. if i slowly reved the engine it slightly dropped to around 15-18 Hg. When i went to wide open throttle quickly, it dropped down to 0. Does anyone know what this might mean? Any help is appreciated.
Old Dec 13, 2008 | 03:08 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: What should a vac. gauge read?
that seems like normal vacuum...
Old Dec 13, 2008 | 03:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's completely normal.
Anchorage?? You got the ***** to drive your thirdgen around in ANCHORAGE, now?!? I was there two weeks ago, I can't even imagine driving a 3rd gen now...
You installed your vac gauge into your air cleaner? Typically these are installed into your carb, or intake manifold, etc.. Or TBI injection unit? If there are ports on it..
Old Dec 13, 2008 | 06:12 PM
Engine: 5.0 TBI
"Sonix: That's completely normal.
You installed your vac gauge into your air cleaner? Typically these are installed into your carb, or intake manifold, etc.. Or TBI injection unit? If there are ports on it.."
Yeah i was driving around.... on summer tires infact. Untill i started having a problem with my bird.
https://www.thirdgen.org/forums/tbi/...ease-help.html
I just hooked it inline to one of the vacuum lines going from the TBI unit to the stock air lid. I cant't remember the name of the sensor off hand.
Ghettobird52
Jul 5, 2024 11:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
Bstrang6
Sep 8, 2015 04:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
