Help Would Be appreciated
Old Dec 12, 2008 | 07:17 PM
DanTeix's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
What is this and what does it do Found a vacuum break thanks for the help
[img=http://img211.imageshack.us/img211/4084/dontknowvr9.th.jpg]
Old Dec 12, 2008 | 07:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Help Would Be appreciated
Heater core bypass valve
Old Dec 12, 2008 | 07:35 PM
DanTeix's Avatar
Engine: 305 TBI
what does it do and what can the vacuum leak cause
Old Dec 12, 2008 | 07:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It bypasses coolant around the heater core when the heater is off.
Vacuum leaks can cause all kinds of issues.
Old Dec 12, 2008 | 07:46 PM
DanTeix's Avatar
Engine: 305 TBI
thank you very much.
I also noticed the vacuum hose leads to the something below the driver headlight if I am not bothering you to much what is that. thanks again
Old Dec 12, 2008 | 07:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the vacuum reserve canister so that vacuum operated accessories will still work during periods of low engine vacuum.
83RDRACR
Mar 26, 2016 08:13 PM
Formula8r89
Sep 22, 2015 04:24 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Denricci22
Sep 18, 2015 09:02 AM
