What kind of Hp am I looking at
Old Dec 12, 2008 | 11:52 PM
log93pow's Avatar
Car: 91 Camaro RS
Engine: Carbd 355
Axle/Gears: Currently 2.73
I have a 355 sbc bored .30 over. It has the wieland Team G intake with a Barry Grant 850 cfm carb. Im running the double hump heads. Not sure on which headers but for sure a high performance one and 1 5/8 in. primaries. What kind of power should this motor be making.
Old Dec 13, 2008 | 12:13 AM
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
Re: What kind of Hp am I looking at
We need more info there log93. like compression ratio. camshaft specs. if the heads have any work on them. to start with.
Old Dec 13, 2008 | 12:21 AM
log93pow's Avatar
Car: 91 Camaro RS
Engine: Carbd 355
Well the compression ratio is 10:1 and not to sure about the cam just know its a 575 lift.
Old Dec 13, 2008 | 01:34 PM
tshack's Avatar
Car: 87 Z28
Axle/Gears: 3:43
Well The best I could get from desktop dyno was
430 Hp 379 Tq @ 6000
432 Hp 349Tq @ 6500
This program is a limited older version. so may be 10 -15 % eather way depending on the tune.
Back in the day those double humps where good, But today's vortecs head out flow ported camel back& so many after market heads are so low priced it's not worth dumping fund in to those heads, IMHO.
Now then if you swap that 850 carb for a 750cfm double pump. & change to 1 3/4" headers or larger. you could gain 50-60 Hp. That's by the program. so you kind of over carbed there .
Old Dec 13, 2008 | 03:12 PM
log93pow's Avatar
Car: 91 Camaro RS
Engine: Carbd 355
[quote=tshack;3976307]Well The best I could get from desktop dyno was
432 Hp 349Tq @ 6500
Thanks for the info
Gunner242
Dec 25, 2015 04:49 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
hartsmike
Oct 2, 2015 07:11 AM
ccop
Convertibles
Sep 14, 2015 04:13 PM
