problem installing pistons
Old Dec 14, 2008 | 03:51 PM
helluvatim's Avatar
Car: 86 Camaro
Engine: 2.8
Transmission: 5-Speed
hey guys, I got a quick question... what is giving me so much resistance when I'm trying to install my pistons in the cylinder? I've built about a dozen motors and this has never happened before.
Its a 90 TPI engine, these are the same pistons going back in, standard bore, with fresh rings on them. Lube em up good, use the ring compressor, the skirt goes in, but locks up around the second ring. I honed the cylinders, so there is no ridge. There is only so much I want to pound on it to get it in.
Is there a chance that the near freezing temps in my garage has made the block contract? Im stumped -Darren
Old Dec 14, 2008 | 04:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: problem installing pistons
Have you checked the ring gap?
Old Dec 14, 2008 | 04:53 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
something that not many people do today . be sure and check at top and bottom of bore . good luck .
Old Dec 21, 2008 | 10:45 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Some standard size pistons are actually a liile oversize to accomadate honing, measure the piston with a mic, and your cylinder with a dial bore guage, see what your clearance is.
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fronzizzle
Aug 17, 2015 02:52 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
