Winter MPG?
Old Dec 14, 2008 | 08:33 PM
90c350's Avatar
Winter MPG?
Just wondering if you guys tend to see a reduction of mileage during the winter months? I seem to be down about 2mpg from usuall in the last few weeks. Temps have been around 5 to 0c outside. Now I do need to put some new plugs/wires on, I can see arcing in the dark etc. Im also wondering if i have a bad A/C compressor, wich I know that I do. Will this cause a loss of mpg as well??? Its not hooked up, so it does not cycle. If it was hooked up still it will almost stall the engine at idle. But seems to be fine when just going along for the ride other than some noise. Any thoughts on this. Also have seen some articles about winter mpg going down do to winter fuel and lack of engine temps etc. Any thoughts on these topics?? Thanks guys!!
Old Dec 14, 2008 | 10:34 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Re: Winter MPG?
my truck (chevy 4.3L) lost approx. 1.5 mpg here in WNY over the past month or two. Keep in mind that I did put a little over 200 Lbs. of weight over the rear axle, which I assume contributes to the loss considerably.
Old Dec 14, 2008 | 11:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Winter MPG?
Probably staying in open loop longer. While in open loop, it will run richer to warm the engine up.
Do everything you can to get the engine hotter quickly. Block off the airflow to the rad. Run a 195* thermostat. Direct warm air into the intake.
Old Dec 15, 2008 | 01:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A 195 thermostat won't get it into closed loop any quicker than a 160 or 180 thermostat, since it goes to closed loop at 110 degrees. But, if the thermostat is stuck partially open, it will increase the warm-up time.
Winter formulations are more volatile than summer blends for easier starting. Could be the formulation change.
Used to notice a drop in mileage during the winter every year here until they went to oxygenated gasoline year round.
tmellott89
Oct 14, 2015 02:06 PM
meeklay812
Oct 1, 2015 03:46 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
James Sutton
Sep 23, 2015 02:18 PM
Formula8r89
Sep 22, 2015 04:24 PM
