Still runs but Engine Has a Knock
Old Dec 15, 2008 | 01:36 AM
Jstuck3y's Avatar
Car: 1985 Camaro
Engine: 305 V8
Transmission: 700RA
Hey guys I found an Iroc Z wit a 305 a guys selling i was interested in getting but the engine has knock they guy says it could be the fly wheel thats causing it to have a knock....I was thinking it had a misfire....Could anyone explain to hw serious the problem is and how hard would be to fix??
Old Dec 15, 2008 | 10:48 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Still runs but Engine Has a Knock
If it's an auto it could be a cracked flexplate. It could also be a spun bearing. I can tell by the sound, but it's not something I can describe. You might try retarding the timing to a few degrees after TDC. This will take much of the load off the bearings. If the noise diminishes, it's new engine time.
Old Dec 15, 2008 | 08:44 PM
TylerP's Avatar
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
I've seen loose torque convertor bolts can an almost rod like knock. The rythem is not the same but at least it's something you can check.
Old Dec 15, 2008 | 09:38 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
if you can take a video of it running with the hood popped and host the video on youtube/myspace/photobucket and then post up the link
that way we can hear the knock
Old Dec 16, 2008 | 12:03 AM
SLOWMARO355's Avatar
Remove the flywheel cover and look for cracks around the bolt area or loose bolts
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
