Cam & what other parts needed?
Old Dec 15, 2008 | 08:19 PM
1970 Buick's Avatar
Car: 1989 GTA
I want to put a better sounding & performing cam in my 89 GTA 350. What other parts are needed for a complete cam install? What cam would you suggest for good low end torque and a lopey sound? I was looking at this cam "Comp cams XE-268H"...Any help or suggestions is greatly appreciated!!!
Old Dec 15, 2008 | 08:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Cam & what other parts needed?
Do you still have the TPI?
Old Dec 15, 2008 | 08:31 PM
1970 Buick's Avatar
Car: 1989 GTA
Yes, sorry I left out a few things. I have the TPI, but thinking of switching to HSR. I have SLP Tri-y headers, 3 inch exhaust w/ cutout, flowmaster 3 inch exhaust, 58 mm TB and thinking of dropping in a lower RPM stall converter..maybe 2500...? Also might add ported plenum, base, and runners.
Old Dec 15, 2008 | 08:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The XE268 is a flat-tappet cam, which would be a waste of your roller block. Unmodified stock heads are going to limit the amount of lift you can get from a cam, and any cam with a lumpy idle will give your computer fits.
Old Dec 15, 2008 | 08:51 PM
1970 Buick's Avatar
Car: 1989 GTA
Thanks for the tip...is there a cam you could suggest?
Old Dec 16, 2008 | 08:31 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
I used a 97 lt1 cam in my recent engine swap and runs pretty good!
Details avail. here https://www.thirdgen.org/forums/engi...l98-vette.html
BTW,hows your taillight center section working?Just wondering because I have never recieved the broken piece back after what,5 months now?
Old Dec 16, 2008 | 09:41 PM
1970 Buick's Avatar
Car: 1989 GTA
Thanks for the info on the cam timmy. How does it sound? I decided to try out some custom work on the taillight center since it was already broken I figured what the heck, couldn't hurt it anymore. Turned out pretty sweet too! Thanks again for the reply.
Old Dec 17, 2008 | 08:22 PM
Engine sounds pretty sweet! The LT1 cam isn't much more than the stock l98 cam but,I can notice a difference! It has a mild choppy idle and requires no tuning which was a plus for me.
By the way,what did you do to the taillights?
midge54
Jan 29, 2017 07:00 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
1nastygta
Aug 8, 2015 07:38 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
