Smoke freaking out girlfriend...
Old Dec 18, 2008 | 10:26 AM
fastlane350's Avatar
Car: 1987 iroc-z
Engine: 350 TPI.. stock :(
Ok so once and awhile... it might be if i put alot of load on the engine right before hand.. my engine will start pouring smoke out from under the hood that smells like burning oil.. its typical for when i shut it off but ive seen it while i was driving before.. ive got the hood open beor but i cant tell where its coming from.. it seems to be by the passanger side exaust manifold, but there is also oil caked onto the valve cover.. so does anyone have a clue where it is coming from? or what i should do here? my girlfriend thinks its gonna blow up.. and its to cold to just start tearing the engine open in the parkinglot without know whats going on..
Old Dec 18, 2008 | 10:41 AM
Sly_dawg19's Avatar
Re: Smoke freaking out girlfriend...
Could be your dipstick seal is bad, or a leaky head.
I knew a guy with a DSM and everytime he gave it gas oil sprayed everywhere from the dipstick being bad.
Old Dec 18, 2008 | 10:48 AM
Car: 1987 iroc-z
ill check that out thx.. sounds alot like what ive got going on..
Old Dec 18, 2008 | 11:00 AM
Stephen's Avatar
Car: 87 GTA
I had smoke pouring out from the hood one day, pulled over & every time I turned the steering wheel, the line pressure from the power steering pump caused it to squirt on the exhaust manifold & catching fire!
I was torn between letting it burn down, because I didn't like the truck & putting it out, because it was my ONLY "car"....My first "car" was a green Ford 1/2 ton truck...I hated that thing SOOOO much, but hey..It was that or nothing.
Old Dec 18, 2008 | 11:36 AM
Car: 1987 iroc-z
Not likely.. there has never been fire, it smells like burning oil, and the power stearing pump is not on the passenger side of my engine.. but rather the front end of the drivers.. very far away from the exaust manifold.. but thx for trying bro..
Old Dec 18, 2008 | 07:34 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
had the same exact problem it was coming out of the dipstick sombody told me to change the pcv valve?(that is the one on the drivers side rocker cover..right/>?) and it stopped
Old Dec 19, 2008 | 02:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Check out the PCV valve, PCV filter, and valve cover gaskets. I'll bet its oil dripping down from one of the valve covers, and a poorly functioning PCV system will not help, especially under load.
Old Dec 19, 2008 | 04:07 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
my money is on the valve cover gasket leaking down the side of the head onto the manifold. very common in many gm cars.
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
