Water/oil crud in breather and PCV but not in pan
Old Dec 18, 2008 | 05:21 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
I changed the valve springs out on my heads a few weeks ago and the car has sat since. The car ran and drove fine after the swap. The car still runs the same but I heard the squeal/squeek sound from the side of the motor so I went to pull the valve covers to make sure the rockers wern't loose. When I pulled the breather and PCV valve they are cover in white crud that looks like a water and oil mixture but there isn't any in the valve cover or on the dip stick. I pulled and cleaned the dip stick multiple time and the oil looked fine other than being low. I can't see any oil in the water. So I don't know. Any thoughts? The motor has about 500 miles on it since the build.
Old Dec 18, 2008 | 09:17 PM
92whiteta's Avatar
Car: 86 WS6 Firebird
Engine: 355
Axle/Gears: 2.73 open
Re: Water/oil crud in breather and PCV but not in pan
that is moisture getting inside there it is fairly normal and wont hurt anything as long as you dont find it inside the motor
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
NZKnight
Oct 15, 2015 02:47 PM
loud91rs
Oct 5, 2015 10:05 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
