HELP! what did i do wrong?
Old Dec 15, 2008 | 07:12 PM
blackdemon89ta's Avatar
I swapped out my 305 to a 350. Before putting in the 350 I put in a cam xe268h and swapped it from tbi to carb. When trying to start the car it doesn't wanna start. I thought i had timing right but it seems like i did something wrong. It either backfires back up the carb or does a gunshot through the exhaust. I tried to readjust the valves but maybe i'm doinng those wrong too.
so any ideas? how could i make sure if timing or valves are right? could i be overlooking something?
Old Dec 15, 2008 | 07:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: HELP! what did i do wrong?
it is very likely you have the timing 180 degrees off, quite easy to do and will cause these symptoms.
The motor come to TDC twice, and you probably have it set to the exhaust stroke as opposed to the intake stroke
Check that first.
Old Dec 15, 2008 | 08:58 PM
TylerP's Avatar
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
Make sure you have the distributer rotation correct to.
Old Dec 15, 2008 | 09:06 PM
distriputor rotation? how can you put it in any other way?
Old Dec 15, 2008 | 09:13 PM
Check that first.
this is what i kinda figured. i just re did the timing.The engine kicking over almost starts but then stalls right away. i'm way off my timing?
Old Dec 15, 2008 | 09:43 PM
TylerP's Avatar
The distributer could be installed wrong like mentioned above of the wire could be on the cap wrong. The distributer spins clockwise but if the wires were put on backwards it would not run either.
Old Dec 15, 2008 | 10:01 PM
hmm i didn't think about that. i'll double check it.
Old Dec 19, 2008 | 04:02 AM
it wasn't the wires. It was 180 off timing and the rockers were tightened too tight.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
