trunk and door lock set replacement!!! HELP
Old Dec 21, 2008 | 04:26 AM
vargasjc's Avatar
I lost my key to the door and trunk of my firebird...i have the key to the cylinder and i can start the car because luckily i left the door unlocked...
I want to change the lock set for the trunk/doors because i am its an open invitation for an esay break in...
I was wondering...has anyone ever changer the whole set and explain to me the easiest way?
I cant even open the trunk from inside the car...(there is no trunk hatch) evenm from inside the car...only way to open it is from outside with the missing key...
Its a 89 firebird...PLEASE HELP!!!
Old Dec 21, 2008 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: trunk and door lock set replacement!!! HELP
The following will provide an idea:
https://www.thirdgen.org/forums/atta...on-manual1.jpg
JamesC
Old Dec 21, 2008 | 09:51 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
$17 for replacement door cylinders and $26 for a new hatch cylinder from AZ.
Old Dec 22, 2008 | 10:43 AM
carzwitballz's Avatar
Car: 91 Camaro RS/2005 Dodge 1500 4X4
Engine: 305/ 5.7 HEMI
I just went through this on my car. I purchased a full set off of ebay. Kinda of a hit or miss on there, But im sure if you post that you need a set on here you will find many have them. They are very simple to R&R. Doors all you have to do is remove the door pannel "be careful not to break any of the body rivits" Once door panel is off you need to reach in and take the retainer off the door lock rod. Once rod is removed there is a retainer clip that holds the lock tumbler in place. Pry that clip off with a screwdriver and the whole peice will come off from the ouside. For your hatch you can remove the bolts holding the pulldown on and beable to take the retaining clip off. Good luck!!
Old Dec 24, 2008 | 05:25 PM
spudz's Avatar
Pull the lock cyl out of one of the doors.. Take it to a local locksmith. They will cut a key for it for like 30 bux.....
Old Dec 24, 2008 | 06:53 PM
vargasjc's Avatar
You sure its $30?
last i heard it was $100 at least
Old Dec 26, 2008 | 06:53 PM
JT's Avatar
JT
Community Administrator
Please don't cross-post into 3 different forums.
https://www.thirdgen.org/forums/body...-lock-set.html
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
