i have some qustshions
Old Dec 22, 2008 | 08:23 AM
matts/irocZ's Avatar
Car: 87 camaro IROC
Engine: 350 \ 305 all most belt
Transmission: 7R4
Axle/Gears: 4.11 9'' POSI
Hey guys i have some qustshions. i have a 305 with work done to it.its mostly all rebelt be sides the crank in pistons. wouldd i have to replace them ? every thing elts is new with high performance parts. The Turbo kit i have hase 2/T4 Turbos would i have to do anny more to the moter to install it. i no you need low compression for turbos right. well if u could help me that would be great..
thanks
matts/irocZ.
Old Dec 23, 2008 | 06:52 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Re: i have some qustshions
my brain hurts
Old Dec 23, 2008 | 06:55 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
You need to list what the rest of your setup includes...it's hard to figure out what you have based on that....um....description.
...and for God's sake use spell check or proofread...damn....
You're probably going to have issues if the crank is in the pistons, that definitely hurts performance. It adds too much weight to the pistons and the motor is going to have a hard time revving to keep up with the turbos. Take the crank out of the pistons to lighten them up...you might want to bore the pistons out too to really lighten them up..................
Old Dec 23, 2008 | 07:27 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Glad to hear you've replaced the belts. You'll have to make sure they are in good shape for the turbo pully's.
Old Dec 23, 2008 | 08:07 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
We tried all that and the car started bogging out of tight corners because there wasn't enough weight in the pistons to keep momentum - it's really important to have crank in pistons for a turbo setup because you need the extra torque until the turbo kicks in.
Old Dec 23, 2008 | 08:27 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Try the smaller turbo pullies like TAdan said. They should spool up faster.
Old Dec 23, 2008 | 12:53 PM
NYC LSC's Avatar
Car: 1987 Lincoln Mark VII LSC
Engine: Novi'ed 304 H.O.
Axle/Gears: 4.10 Trac-Lok w/ Moser axles
Purt end polesh the heds end entayk. Yew ken yews sand threw the entayk toob to dew it. Werks lyk a cherm.
Old Dec 23, 2008 | 02:02 PM
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
How low of compression are you running? You don't want anymore than 85 PSI when you do a compression test on the motor, otherwise you might run into problems with boost.
Old Dec 23, 2008 | 02:24 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Drill a small hole through the top of each piston will reduce the compression nicely.
Old Dec 23, 2008 | 10:25 PM
S00828822's Avatar
Car: 1984 Z-28 and 1989 GTA Trans Am
On your next trip to Summit, you'll need:
-new fuel system (complete from fuel pump to injectors)
-new ignition system
-new pistons, rods, rings, crank, etc, etc, unless you want to send your crankshaft flying through your oil pan.
-and honestly by the time youre all done with this youd be better of with a mild 350 crate in there. Trust me.
Good luck tho bud.
