Banging noise please help
Old Dec 22, 2008 | 07:39 PM
bcfipp's Avatar
When i put the gas pedal to the floor I hear and feel a bang under the car. I was wondering if anybody new what it could be. When i gradually speed up it doesn;t happen. Also my speedo needle sticks a little anyway to fix that. thanx
Old Dec 22, 2008 | 07:52 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Banging noise please help
Inspect the transmission mount.
Old Dec 22, 2008 | 07:55 PM
bcfipp's Avatar
That I will do thanks
Old Dec 22, 2008 | 08:01 PM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
x2
Most likely you have a cracked or dry rotted mount.
Old Dec 22, 2008 | 08:14 PM
MYZ28NH's Avatar
Car: 91 Z28 Convertible
My car does the same thing. Was hoping it was just weak rear shocks. Let us know when you find out.
Old Dec 22, 2008 | 08:17 PM
Stippy17's Avatar
Tranny mounts arent expensive or hard to replace. They cost about $10 at your local parts store, and when I did mine it took me 10 minutes.
Old Dec 22, 2008 | 08:43 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
yeperz a trans mount, may i suggest an energy one, and a energy tq arm bushing also
Old Dec 22, 2008 | 09:27 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
when the tranny mount was gone in my car the whole car used to vibrate at higher speeds got that problem?
Old Dec 23, 2008 | 06:27 PM
bcfipp's Avatar
It was the tranny mount. It was rotted out. It has been replaced, and it solved the issue.
Old Dec 23, 2008 | 06:36 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sure if we knew you car's details: year, make, model.
JamesC
Old Dec 23, 2008 | 07:34 PM
Stippy17's Avatar
Cool glad to help.
Old Dec 23, 2008 | 07:46 PM
bcfipp's Avatar
1991 chevy camaro z28 with a 305 tpi motor
UltRoadWarrior9
Apr 28, 2020 10:39 PM
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
