Broke distributor gear did it mess up the cam gear?
Old Dec 22, 2008 | 11:36 PM
PPM's Avatar
PPM
Car: 1991 Chevrolet Camaro Z28
Transmission: Tremac T-56 6 Speed
Axle/Gears: 10 Bolt 3.73 POSI
I broke my distributor gear because i used the iron instead of brass gear on a roller cam.
Has this happened to any one and can they tell me if i broke or damaged the cam gear?
Old Dec 26, 2008 | 04:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Broke distributor gear did it mess up the cam gear?
How did it break?
Old Dec 26, 2008 | 09:44 PM
PPM's Avatar
PPM
not sure. i dropped the distributor in new. drove barely a block and it died. took off the dist. cap and noticed the rotor wasnt spinning like it should.
then tryed to remove it but it was stuck.
finally pryed it out and a big chunk of the distribor gear was broken off.
Old Dec 27, 2008 | 12:20 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
I could not tell you, I have always used bronze gears with roller cams, I would say that I would want to get the rest of that dist. gear out of the oil pan, even if you got the chunk, I am sure there is shrapnel in there. More than likely you messed up the cam gear, you may put a Bronze gear on there and it work, but if the cam gear is rough or deformed even a little bit, then it will eat dist. gears like mad.
junkcltr
Aug 2, 2019 11:12 PM
jklein337
Sep 19, 2018 06:23 PM
italiano67
Dec 11, 2016 09:21 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
cstrobel65
Aug 15, 2015 10:19 AM
