AIR pump delete pulley too small
Old Dec 26, 2008 | 11:13 AM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
Just installed the delete pulley (305 TPI) and the stock belt doesn't fit. The new pulley is noticeably smaller than that on the pump. Can I just run the disconnected pump with the air hole blocked off (or not blocked off), or would it be better to get a smaller belt? I don't think I have enough room to take up the slack with the tensioner and I thought the pulley worked with the stock belt. Thanks
Old Dec 26, 2008 | 12:13 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: AIR pump delete pulley too small
Here are two link that you might find helpful:
https://www.thirdgen.org/serpentine
http://sethirdgen.org/serpentine.htm
JamesC
Old Dec 26, 2008 | 12:35 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
I just run a smaller belt and no AIR delete pulley. Hasent given me any issues.
Old Dec 26, 2008 | 01:53 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
is that the belt mentioned in the tech article? They refer to that belt being longer than stock.
Old Dec 26, 2008 | 02:20 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Guess its longer then, I cant remember. But yes, I used the one from the tech article. It fit fine.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
actionj
Carburetors
Aug 16, 2015 09:51 AM
mcquigg
Aug 13, 2015 02:26 PM
