good start for my 91 mods?
Old Dec 27, 2008 | 04:48 PM
bird91305's Avatar
New to board, and new to Third Gen upgrading as well. (Old school muscle-car guy). Anyway, I have a stock '91 Firebird 305 TBI. Love the car and just am planning mild upgrades. Here's what's I will be doing, just looking for any constructive criticism or alternate plans. Thanks!
Remove A.I.R. system (mostly for improved access and looks)
Dynomax 2 1/2" or Jeg's 3" cat-back system (have both), Jegs is poorly constructed and missing hangers, Dynomax looks like a slam-dunk to install.
swap 2.73 axle for 3.08 (I have the 3.08 posi out of my '85 Berlinetta)
Buick GN fan switch, Redline watter wetter or like-type product with 180* balanced valve type (Milodon, etc) thermostat
shift kit and trans cooler for the 700r4
Steering brace
Poly sway bar and end-link bushings
235-60x15 tires to replace the 215-65's currently on car (stock 15x7 aluminum rims)
open element air cleaner
fuel injector spacer
4-8* initial timing
Swap swirl-port heads for a set of fresh 416-casting 305 H.O. heads (I already have the heads)
I just want a slightly better performing, cooler running, and better handling vehicle. My car has the "soft-ride" suspension option, so I'm thinking maybe I ought to go with the Trans Am front coils as well.
Car has T-tops, so I may also be looking at sub-frame connectors if I can find some that don't interfere with the exhaust and don't cost an arm and a leg!
These mods are what will be happening immediately, down the road I may look at more gearing, better shocks/struts, and more poly bushings.
Old Dec 28, 2008 | 03:50 PM
Dakine858's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1L V6
Re: good start for my 91 mods?
Steering brace
4-8* initial timing
Move the sub frame connectors up towards the top of your list. You don't have to waste money on a pre-fab'd kit, just get a few lengths of rectangular steel tubing and cut/weld your own. I did mine for under $40.
Old Dec 28, 2008 | 04:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I'd put headers/catback and sub frame connectors up near the top of that list. You'll get the most benefit, initially, from those two.
Old Dec 28, 2008 | 06:21 PM
bird91305's Avatar
Thanks! I will be doing the subframe connectors, what I listed in my original post was what I had on hand right now. I also have headers and y-pipe from my '85 which will be going on eventually. Right now there is nothing after the cat, so I need to address that first. Do the rest of my mods sound reasonable?
Old Dec 28, 2008 | 09:51 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If the 416's are just sitting around, why not look into some DIY port work, make them flow decent.
Maybe consider a mild cam upgrade (LT1 cam would be a decent upgrade). Look over the LT1 Cam sticky in the TBI boards, if you haven't already. Between this and better flowing heads, that's the next largest seat-of-the-pants improvement.
The rest looks pretty reasonable.
Old Dec 28, 2008 | 10:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Just remember that's illegal on a street car in all 50 states, regardless of if your area does emissions checks or not. And if your area does do emissions checks, you might not pass the test.
For more ideas, see the Ultimate TBI tech articles on this website, and search the TBI forum.
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
drathaar907
Aug 6, 2015 04:20 PM
