Starter relay location
Old Jan 6, 2009 | 05:37 PM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
I have a start problem on my 89 TA TBI. It wont turn over. I have replaced the battery and tried to start it again. Wondering if anyone knows where the start relay is to check it there. Otherwise, what may I be looking for? I have the Haynes Repair manual.
Old Jan 6, 2009 | 09:02 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Starter relay location
There is no relay, it's built into the solenoid. Have you tried jumping the solenoid wires?
Old Jan 6, 2009 | 09:11 PM
TA-Rocks's Avatar
Not yet, I will do that when the weather breaks. Im confused about the wiring, then. I have the Haynes repair manual. It indicates that '90 and later with passkey has a relay before the gear selector switch then the starter. My car has a resistor passkey but its a 1989. The book don't indicate that on 1985-'89. So do I go by the wiring on the 1990 or older wiring adding passkey, not shown in diagram?
Old Jan 6, 2009 | 09:15 PM
chevy89camaro's Avatar
passkey was introduced in 89 and made standard...follow your 89 diagrams
Old Jan 6, 2009 | 10:57 PM
jv9999's Avatar
Engine: 5.7L/350
Yea, sorry, didn't realize it's a VATS car. This thread may help: https://www.thirdgen.org/forums/elec...pass-vats.html
Nick McCardle
Sep 10, 2015 08:36 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
tonys91rs
Sep 2, 2015 07:07 PM
