Distributor Installation Help
Old Jan 7, 2009 | 05:57 PM
Joes1wood's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 Liter
Axle/Gears: 10 bolt 3.55 POSI
I'm putting a new distributor in my 1985 LG4 equipped Z28. I marked all the spots, but when I put the new unit in place, everything lines up, just the Tac and Bat terminals are in the front, not on the driver's side (as they were before). Can I turn the distributor to where I want the tach and battery terminals, then use another nipple for cyl. 1? My timing is in the ballpark also.
Is this the correct solution? Or must I do something else?
Old Jan 7, 2009 | 06:18 PM
doctorcad's Avatar
Re: Distributor Installation Help
Yep, should be okay. You will of course have to set the base timing with a timing light though.
Old Jan 7, 2009 | 06:46 PM
hotrod7687's Avatar
Car: '91 Camaro, 90 Formula
Engine: 355 carb, 305 TPI
Transmission: TH 350, 700R4
If youre having to rotate the distributor that much to get the timing close, i would suspect that you were somewhat off when you installed the new distributor.
You can use any nipple you want as #1 cylinder you just have to make sure that #1 piston is at TDC compression stroke. Make sure that you run the plug wire from the nipple you choose to #1 plug.
Honestly its easier to just time it like its supposed to be with the right nipple as #1.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 07:57 PM
stalkier
Aug 7, 2015 04:49 AM
