One Side of Motor Running Really Hot
Old Jan 9, 2009 | 03:24 PM
visionpb16's Avatar
I have a 1991 Camaro Z28 with a 5.7 TPI engine. The mods to the engine are: bored .30 over, ported heads, 1.6 roller rockers, a hydraulic roller cam,
mini-ram intake , 58 mm holley throttle body, and headers. This is a new a motor and still not yet been broken in. To manage the motor I bought the EBL flash system. It seem like a good system, although I have been having trouble getting the car to idle but I not spent that much time playing with the EBL system to get it tuned right. This isn't my biggest problem though. When I was running the car at around 2500 rpm for a couple minutes to break in the cam on side of the motor got really hot. The headers of that side were glowing orange, once I saw this I shut off the car. After waiting a minute or so the cooler sides headers were already cool enough to touch, while the hotter sides headers I wouldn't dare to touch. I don't really know how hot the engine got on the hotter side cause the coolant temp sensor is on the cooler side and according to it the engine only got 175 F. Any ideas?
Old Jan 9, 2009 | 04:07 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
COOK DINNER ON THAT SIDE WHILE TAKING A FEW PRACTICE LAPS
It could be uneven fuel distribution.
Pull and read the plugs.
Also, with a propane wand check for vacuum leaks.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Jan 9, 2009 | 05:21 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: One Side of Motor Running Really Hot
Sounds like one side of the engine is running lean. Could be bad fuel injectors on that side.
Old Jan 9, 2009 | 07:43 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I thought breaking in an engine with headers was a big no-no?
Check out the plugs...see what they tell you
Old Jan 9, 2009 | 07:57 PM
Foxhall1337's Avatar
Car: 1989 Formula ws6
Engine: 305 TBI
Axle/Gears: Detroit Locker 3.73
I had this happen to me with a regular tbi 305. One of my pushrods where bent "i believe intake" so it acumulated alot of unburnt fuel on that side and would get the exhaust glowing red hot on just that side."Wasnt bent enough to cause a miss, just enough to limit the intake on that cylander which would also make it run lean" ALSO what kind of exhaust are you using dual? y-pipe? Maybe its a slight clog. Are all 4 header tubes bright red or do u have 1 that sticks out.
Old Jan 9, 2009 | 08:09 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: COOK DINNER ON THAT SIDE WHILE TAKING A FEW PRACTICE LAPS
Originally Posted by NINÅ
..If People Drove Any Slower They’d Be Going Backwards
anyway, one bank is prob to rich and the other is to lean, IDK but like said you need to pull the plugs and check them out.....maybe your headers shouldnt be glowing at all, only time i had a set glow was pulling a big hill with a 460 ford and about 26,000+ GVW
you should get an infrared thromo and see how hot each port is getting, that may help you find your problem faster
Old Jan 10, 2009 | 02:58 AM
chevy89camaro's Avatar
seems like a fuel problem.... you have all the lifters set right?
Old Jan 10, 2009 | 03:04 AM
before i rebuilt my 305 the stock manifolds used to turn birght orange when ran alittle hard. during the night at normal cruz if you popped the hood they were always slightly orange. during rebuild i found 5 bent pushrods. 2 were very bad. if you rolled one end on table the other ends of pushrods lobed 1/8in to 1/4in in air. (off table) lol
Old Jan 23, 2009 | 01:51 AM
visionpb16's Avatar
With some help from another member i figured out that one of the injector fuses was blown. The "fuel injector feed #1" fuse. I put a new fuse in and it blew right out again once i tried to start the car again. Any ideas?
Old Jan 23, 2009 | 02:06 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
gona say there may be a wiring problem.
Old Jan 23, 2009 | 04:10 AM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
I dont know if it could be anything other than a short to ground somewhere. I had one when I installed my new motor when a wire was pinched between the trans and engine...worth a look.
looks like its time to start tracing wires
Old Jan 23, 2009 | 10:03 PM
im betting your problem is at the throttle body. check your injector wires closely. probably shorted against the body.
Old Jan 23, 2009 | 10:59 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
You have a dead short somewhere in that circuit for sure.Time to start tracing wires and look for any bare or pinched wires. I don't see how it could be in throttlebody though, as it merely directs metered air into a plenum that feeds all the cylinders.
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
Elliswon
Aug 10, 2015 12:33 PM
