guys i need help wit this?
Old Jan 10, 2009 | 04:35 PM
5.0slayer's Avatar
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
i got a brand new set of heads they r 2.08 int and 1.6 exh, i need to know what the valve diamiter of the stem and the seat pressure and instal hight and all that stuff, all i have r the heads nothing else,
the engine is hydrolic flat tappied, and has a .488 lift and a 234 duration its a carb motor,
anything else ask i will get you the info u need, i would rather have summit part numbers seeing how i dont like far from there,
Old Jan 10, 2009 | 04:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: guys i need help wit this?
You'll need to measure the diameter of the stem. Installed height and seat pressure depends on whatever springs you have.
Old Jan 10, 2009 | 04:51 PM
5.0slayer's Avatar
Car: 91 camaro RS
thats the thing i dont have then there bare heads im going to build them, just idk what parts to buy, that what i need help with,
Old Jan 10, 2009 | 04:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Buy whatever springs the cam manufacturer recommends for that cam, and install them to whatever installed height they recommend.
Old Jan 10, 2009 | 06:52 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Take your heads to a machine shop that works on cylinder heads. They can measure them for you. That's the only way to find out what your asking -is to measure what you've got there.
Amillionoh7
May 24, 2020 08:01 AM
aaron7
Aug 17, 2016 06:02 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Chiknhawk
Aug 23, 2015 05:54 PM
Street Lethal
Aug 14, 2015 08:25 PM
