Timing Light purchase advice needed.
Old Jan 11, 2009 | 08:25 PM
Trick414's Avatar
Car: 1991 RS Vert
Engine: LO3, 305, TBI
Heyas!
(Did a search going back several months, didn't find anything useful.)
Last summer I bought a cheapo $50 timing light from the auto store when I did a tune-up. It worked a few times and then died.
I took it back and got it swapped out for a new one. It worked fine while I finished the tune up.
This weekend I put in a new distributor and same problem... it died on me.
So, I decided that I should buy a real timing light.
What model should I get? I don't mind spending a few bucks, just so I get a nice one that won't crap out again.
Thanks!
Old Jan 11, 2009 | 08:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Timing Light purchase advice needed.
I've had a relatively cheap parts store Equus/Innova digital dial-back light for years.
Old Jan 11, 2009 | 08:47 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Just had a Sears/Craftsman light die that was at least 30 years old. I replaced it with another Craftsman.
Old Jan 11, 2009 | 08:51 PM
creese187's Avatar
yeah i would go to sears
Old Jan 11, 2009 | 10:45 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
I have a quik Q about this topic.
I have an actron 7529 it's a 2/4 cycle.
Will this work on my 84 trans am?
prob a stupid question.
Old Jan 11, 2009 | 10:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It should
Old Jan 11, 2009 | 11:47 PM
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
thanks
I was thinking it was a 2 or 4 cylinder for some reason.
silly me.
Old Jan 12, 2009 | 02:34 AM
ljnowell's Avatar
I have a 25 year old sun pro that my uncle gave me back in '94. Works like a charm.
Old Jan 12, 2009 | 02:39 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
As long as it's not so old that it expects to pierce the plug wire, just about any timing light should work.
Old Jan 12, 2009 | 12:49 PM
Renntek08's Avatar
Not sure exactly what you're using it for. Since you're spending the bucks anyway, maybee opt for a unit with a timing advance feature. It's not needed for basic tune ups, but sure makes high rpm total advance readings a lot easier. Sears has one for about $75 bucks.
Old Jan 12, 2009 | 01:57 PM
Trick414's Avatar
Car: 1991 RS Vert
Thanks for the replies everyone.
Looks like a Sears model will last a bit longer than the two I had. Each one of them only lasted about 2 uses.
I checked the manual on it and didn't notice any special procedures that I messed up that might cause it to fail.
So, I just want to make sure I get a decent one that will last. Generally, I buy pretty good tools because you can keep them forever.
However, I didn't think a timing light, for the very little use I would give it, would go bad so easily. Once again, I got bit by false economy.
Thanks!
Vintageracer
Jan 10, 2020 05:33 PM
Andrew6.688
Dec 13, 2015 10:59 AM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
Thirim
Aug 9, 2015 06:19 PM
