water pump easy-out? HELP
Old Jan 12, 2009 | 09:28 PM
SDCamaro1904's Avatar
Car: 1984 Camaro Z28
Engine: 305 H.O
well here it goes so i replace my water pump and i used a 3/8 allen to get the bolt i guess u can call it where my heater hose nipple goes but it stripped out and now im debating if i should drill through it and use an easy out to extract it what do you guys think? i guess i can always get a new water pump cheap... but i dont feel like going through the hassle again to install it...also drilling through the bolt i think will cause metal shavings to fall into water pump so im kinda iffy about it... should i just go for the easy out and if it fails just get a new water pump?
Old Jan 12, 2009 | 09:40 PM
SSWOLZ02's Avatar
Car: 92 Camaro RS
Engine: 88' L98 w/92 tpi conversion
Axle/Gears: Stock one tire Fire!
Re: water pump easy-out? HELP
your almost gonna have to remove it to drill it out. i wouldnt want to get metal shavings in the engine
Old Jan 12, 2009 | 11:39 PM
Engine: 305 H.O
yeah same i think im just gonna say the hell with it and try it anyways and if it doesnt work ill just bite the bullet and get another
Old Jan 12, 2009 | 11:54 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Don't even bother, a new water pump is $17. easy out's are garbage, every time I've used one it's broken off in whatever I was trying to get out making the job 10x harder. A broken drill bit or EZ out is about 1/3 the price of a new pump.
$17 at advance auto parts if you have one near you, autozone should be similar. http://www.partsamerica.com/ProductD...ype=54&PTSet=A
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
