Fuel Pump Problems???
Old Jan 13, 2009 | 05:39 PM
1HRDROC's Avatar
Car: 1990 IROC-Z
Transmission: It's no fun if it ain't a stick!!
Is there any way to tell, under normal operating conditions if the fuel pump is headed out the door? Like say for instance: when accelerating, there is hesitation in the gas pedal! And not even just that. Sometimes it feels like I'm losing something as I'm driving! Anybody?????
Old Jan 13, 2009 | 05:58 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: Fuel Pump Problems???
Definatly sounds like the same problem i had when my pump went out.
Old Jan 13, 2009 | 08:28 PM
creese187's Avatar
the easiest and most sure thing to do, assuming that the pump is getting proper power and ground, and the relay is good. would be to get a fuel pressure gauge with a long hose, and hook it up like you are checking fuel pressure, route the long hose under the hood and up the cowl by the wipers, close the hood, and tape the gauge to the window so you can see it clearly, now just drive the car as you would, and monitor the gauge when the vehicle is acting up, if there is a loss of pressure during malfunction, than you most likely have a tired pump. i think stock pressure is somewhere around 40 psi.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
