Felpro headgasket
Old Jan 8, 2009 | 10:55 AM
fychelio's Avatar
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
Felpro headgasket
anyone know which side should be top or bottom, i bought a felpro gasket set and the head gasket is not printed top or bottom. can i use either side?
Old Jan 8, 2009 | 11:08 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Felpro headgasket
logo that is stamped in them goes up
Old Jan 8, 2009 | 11:13 AM
fychelio's Avatar
Axle/Gears: ????
my dad got the old gasket that was marked and put it on the same way as the old one just now... like literally 3 minutes ago and torqued the driver side down... but it was the opposite way, can we reuse it if we untorque it, or should we just get new gaskets
Old Jan 12, 2009 | 09:30 AM
sgreen3's Avatar
Car: 1984 Z28
Engine: 355ci
Transmission: WC T-5 (untill it breaks)
Axle/Gears: 3.73 Posi
Once they are torqued its recomended that they be replaced, they crush to prevent leaks, so it may not re-seal if you torque it again
Old Jan 14, 2009 | 03:30 AM
fychelio's Avatar
Axle/Gears: ????
hey thanks, i ended up just leaving it the way i put it (logo down) since thats was the direction of the original gasket and i found a folded piece of paper in the head gasket set that said, and i almost qoute " follow the directions of the imprints on the gasket, if no such imprint exsist Install gasket" that was pretty much dead on what it said minus a word or two.
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
GoonieZ28
Aftermarket Product Review
Aug 4, 2002 07:34 PM
vortech305
Mar 27, 2001 04:09 PM
Blade
Jul 31, 2000 07:50 PM
