Oil for 383 engine
Subscribe
Jan 13, 2009 | 09:33 PM
Kinda a dumb question but what kind of oil do I put in my 383 the guy helping me build it says that its going to need a extremly lubricating oil sorta like diesel engines have so if any of you have an insight on this that would be great.
Reply 0
Jan 13, 2009 | 09:48 PM
Re: Oil for 383 engine
rotella will suffice. you just need oil with ZPPD aka the Zinc high pressure additive.
race oils have it and diesel oil has it. regular oils dont.
Reply 0
Jan 13, 2009 | 09:59 PM
Just curious but why does he need this oil?
Reply 0
Jan 13, 2009 | 10:34 PM
Quote: Just curious but why does he need this oil?
He does if he's using a non-roller cam. If using a roller cam, then its not really necessary... pretty much any quality 10-30 would be fine. Synthetic would be ideal.
Diesel oils don't really have sufficient zinc anymore, though still more than 'car' oil does... would need either a 'racing oil' or use whatever oil and a bottle of EOS. If he's using a flat tappet cam. With a roller cam, he can use basically any good quality dyno or synthetic oil. I use a synthetic 5-30 in my LT1 and 10-30 synthetic with a bottle of EOS in my '83s 350 (which has a flat tappet Comp cam).
Can get EOS at any GM dealer's part counter.
Reply 0
Jan 13, 2009 | 11:12 PM
OK I am going for a lunati cam which I believe is flat tappet its got about 256 lift at .5 but just any eos additive to oil will work. More perferred with synthetics?
Reply 0
Jan 14, 2009 | 12:18 AM
I run Delo 400 LE 15w40 in my 383 stroker because it has a flat tappet camshaft.
Check out this site. It will tell you why.
http://www.chevelles.com/forums/showthread.php?t=195620
Reply 0
Jan 14, 2009 | 07:35 AM
Alright, Thanks there's a lot of information there(though I don't under stand most of it) I'm sure it will be helpful to the guy helping me build my motor.
Reply 0
Jan 14, 2009 | 08:12 AM
Use VRI racing oil and you should be set. When I put my lunati cam in I called them and asked what they recommed and they said use VR1.
Reply 0
Jan 14, 2009 | 11:22 AM
Quote: Use VRI racing oil and you should be set. When I put my lunati cam in I called them and asked what they recommed and they said use VR1.
VR1 RACE -20W-50 - 1040/840
VR1 RACE -10W-40 - 1160/912
As you can see there is not enough zddp in ZR1 to break in a flat tappet cam. That is unless you want to use an oil additive to increase it.
An engine with a flat tappet cam NEEDS between 1200-1400 and VR1 falls short. The second number is phospherus which is ok to be a little lower ~1100.
Use:
CHEVRON DELO LE CJ 15W-40 - 1360/1115(CONVEN OIL)
unless you know what is in the oil you are using.
In fact, here is what you need to know out of that thread:
1200ppm-1400ppm ZDDP/ Zn & P is where we need to be for minimum protection when running an aftermarket high perf flat tappet hyd or solid perf cam with elevated spring rates which is what many of us are running in our SBC/BBC motors. If your running a wild flat tappet cam cam with very high spring rates you should run closer to or above the 1400ppm end of the scale for Zinc IMHO.
Scott
(KEY=Zn-ppm/P-ppm)
VALVOLINE NSL RACE(not VR1) -20W-50 - 1250/1000(ALL 4 VALVOLINE OILS LISTED HERE ARE CONVENTIONAL)
" " NSL RACE -10W-30 - 1000/750
" " VR1 RACE -20W-50 - 1040/840
" " VR1 RACE -10W-40 - 1160/912
BRAD PENN RACE - 20W-50 - 770/600 (SYN BLEND)
PENNZOIL GT 25W-50 RACING OIL - 1676/1483 (CONVEN OIL)
CASTROL SYNTEC TRUCK & 4X4 15W-40 - 1240/990(SYN BELND)
SHELL ROTEALLA 30WT SINGLE GRADE -1215/1050 (CONVEN OIL)
LUBRIPLATE GPO H/D 15W-40 - 1165/920 (CONVEN OIL)
ROYAL PURPLE 5W30 XPR Racing Oil - 1421/1339 (FULL SYN/TESTED BY FELLOW T/C'R)
Reply 0
Jan 14, 2009 | 11:30 AM
I just broke in my 383 and flat tappet using 5 quarts of delo 400 and 1/2 a pint of lucas break in lube that is available at most parts stores. It went very well and I had no problems AT ALL. Don't screw around with oils that lack zddp. They will knock the lobes right off your cam.
Reply 0
Jan 14, 2009 | 11:43 AM
Use:
Scott
(KEY=Zn-ppm/P-ppm)
You shouldnt cut and paste old info from other websites. The info on the VR1 oil is wrong and who knows about the other stuff. The Valvoline website says different I can post the link if you need me too.
Reply 0
Jan 14, 2009 | 12:29 PM
Quote: You shouldnt cut and paste old info from other websites. The info on the VR1 oil is wrong and who knows about the other stuff. The Valvoline website says different I can post the link if you need me too.
I checked the Valvoline website and they claim to have 1400/1300 so I guess it's good as long as that is correct. The guy who posted that stuff on chevelles.com has spent a lot of time and money to have oils lab tested and compared to the manufacturer's specs. Rotella CJ got busted for claiming 1200 and having <1000. Delo CJ has been tested 3x and every time it is accurate to the manufacturer's specs. I'm not saying that valvoline is lying, but that when this guy had their oils lab tested in july 2008, that was the result. Also the valvoline webiste says that their tests were conducted in dec 2008 to replace the test done in 2006. Maybe they have changed their zddp level since this guy had it tested.
Reply 0
Jan 14, 2009 | 12:34 PM
What some guy says he did and what the product actually is are 2 different things. The government and other places check to make sure all these oils are up to snuff thats why they get labeled accordingly. Just cause some t@rd on chevelles.com says something dosent mean its true its all hear say off the internet.
Reply 0
Jan 14, 2009 | 01:24 PM
Quote: What some guy says he did and what the product actually is are 2 different things. The government and other places check to make sure all these oils are up to snuff thats why they get labeled accordingly. Just cause some t@rd on chevelles.com says something dosent mean its true its all hear say off the internet.
Just cause some t@rd from the trustworthy government rubber stamps something doesn't mean it's true either.
Reply 0
Jan 14, 2009 | 01:40 PM
Quote: Just cause some t@rd from the trustworthy government rubber stamps something doesn't mean it's true either.
I beg to differ but im not getting into a pissing match over this.
Reply 0
Jan 14, 2009 | 02:02 PM
Quote: rotella will suffice. you just need oil with ZPPD aka the Zinc high pressure additive.
Just in case anyone with a flat tappet cam is looking for the zinc additive - its actually ZDDP, not ZPPD. Stands for Zinc Dialkyl-Dithio-Phosphate.
Reply 0
Jan 14, 2009 | 02:19 PM
I know you love your vr1 and it's prob very good stuff. I'm not trying to argue with you over this. That "t@rd" aka Scott who tested the oils has NOTHING to gain from lying on tha intraweb. He wants the best oil for his car and is generous enough to share his findings with the rest of the online community. I doubt the government cares about our out-dated flat-tappet cams either. Did you even read any of the post in that thread?
Reply 0
Jan 14, 2009 | 02:44 PM
Quote: I know you love your vr1 and it's prob very good stuff. I'm not trying to argue with you over this. That "t@rd" aka Scott who tested the oils has NOTHING to gain from lying on tha intraweb. He wants the best oil for his car and is generous enough to share his findings with the rest of the online community. I doubt the government cares about our out-dated flat-tappet cams either. Did you even read any of the post in that thread?
Yes I read your home boys write up or copy and paste whatever you wanna call it. I will actually copy and paste this just for you
May 26th, 07, 11:31 AM
SWHEATON vbmenu_register("postmenu_1361708", true);
Team Member
Re: Running Diesel Oil Then You Must Read This
Harris,about 6 months ago i did post a list of accdeptable oils but things are constantly changing these days .
Brad Penn racing 10w-30 or 20w-50 or Valvoline 20w-50 R1 racing oil that says NSL/NOT STEEET LEAGAL and also reffereneces ZDDP/zinc on the label are a good choice (for now) if you dont want to run the diesel oil.
Scott
Gotta love VR1 oil
Reply 0
Jan 14, 2009 | 09:33 PM
Quote: Yes I read your home boys write up or copy and paste whatever you wanna call it. I will actually copy and paste this just for you
Team Member
Scott
Gotta love VR1 oil
If you actually read my copy and paste or even the one you just posted, it says that Valvoline NSL 20w50 (which is what is being talked about in your post) is on the list for good oil since it has over 1200zinc. That is not regular VR1, that is Valvoline NSL race and only the 20w50 grade. The regular valvoline VR1 oils 20w50 and 10w40 are just shy of the 1200 mark needed for our cams. BTW NSL stands for "not street legal" and I dunno about you but I dont want to run 20w50 in my car.
Here is another post off that site from the day before your copy and paste, May 25th:
"I had the Valvoline NSL & VR1 oils tested and the NSL racing 20w-50 just squeeked in at approx 1250 ppm ZN & 1100ppm P but the v1 was just under 1200ppm for Zn."
This compliments your post. Notice that NSL and VR1 are different oils and only the 20w50 NSL has enough zddp, not the VR1 20w50.
This "t@ard" says however that you should be okay running your VR1 10w30 as long as you add some oil additive such as GM EOS:
"Rick,since you dont state if its for cam breakin or ongoing use post cam/lfter breakin i would suggest valvoline's NSL or Vr1 10w-30 both conventional race oils since you say you want to run 10w-30 along with a full pint of gm eos."
Notice, " with a full pint of gm eos"
He goes on to say that:
"Then post cam/lfter breakin i would use 1/2 pint eos with the above mentioned oils for ongoing flat tappet cam/lifter protection.
But there are on ther conventiontional oils that like chevron deo 15w-40 that have enough ZDDP to properly prtect your cam/lfters without the additional 1/2 pint eos . But if you want to run a 1/2 of EOS for piece of mind esp if your running a fairly hot flat tappet cam with hi spring rates thats fine too.
But if your going to use just any genaric over the counter 10-30 SM/SL rated oil with a flat tappet cam you need to run a full pint of eos becasue the zddp lvl is only approx 800-850ppm in thoses lighter fuel conserving grades of oil when it needs to be approx 1200ppm-1400ppm zddp for safe flat tappet cam protection."
Which supports all my previous posts on why I choose to run delo 400 15w40. Seems legit to me. VR1 is fine to break in a cam or run post break in as long as you use an additive to ensure protection.
Reply 0
Jan 15, 2009 | 12:19 AM
Use a petroleum diesel oil to break in the cam & rings, then go to a quality synthetic diesel oil.
My choice - http://www.amsoil.com/storefront/hdd.aspx
With flat tappet lifters, avoid oils with the ILSAC GF-4 rating, and look for the CI-4 + (diesel) rating.
Reply 0
Jan 15, 2009 | 08:03 AM
Quote: If you actually read my copy and paste or even the one you just posted, it says that Valvoline NSL 20w50 (which is what is being talked about in your post) is on the list for good oil since it has over 1200zinc. That is not regular VR1, that is Valvoline NSL race and only the 20w50 grade. The regular valvoline VR1 oils 20w50 and 10w40 are just shy of the 1200 mark needed for our cams. BTW NSL stands for "not street legal" and I dunno about you but I dont want to run 20w50 in my car.
Sounds like your trying to convinence yourself about your facts. You and your boyfriends facts are wrong bottom line. The manufacturer has the facts right on it website. If you want to continue to go by hear say go for it. I am done worrying about this copy and paste cr@p from you. When you get some legit facts from are real place other than team chevelles cut and paste then PM me anytime.
Reply 0
Jan 15, 2009 | 12:36 PM
Quote: Sounds like your trying to convinence yourself about your facts. You and your boyfriends facts are wrong bottom line. The manufacturer has the facts right on it website. If you want to continue to go by hear say go for it. I am done worrying about this copy and paste cr@p from you. When you get some legit facts from are real place other than team chevelles cut and paste then PM me anytime.
I see once again you respond with cheap insults. I have presented evidence that the manufacturer's website is wrong except for NSL 20w50. You haven't contributed "cr@p" to this thread. I win. Have a good day.
Reply 0
Jan 15, 2009 | 12:55 PM
WTH is up with the whiney high school emo fighting going on here? Your boyfriend comments? I gotta guess that we have a gaggle of teenagers on here.
Use whatever oil makes you feel good. As far as getting into zinc and ppm and all that stuff, I can say this: I have broken in countless engines in the past with nothing but off the shelf valvoline conventional oil. None of thes engines have experienced a failed cam or bad rings. The only engine that I have ever had a cam fail in was a roller cam made by comp cams. It was a bad cam core.
Reply 0
Jan 15, 2009 | 08:31 PM
You're right. This thread is stupid. The op needs to run a break in lube with whatever oil he chooses to break in his engine with anyways. Discussion over.
Reply 0
Jan 15, 2009 | 10:23 PM
-.- lol I am a teenager and I posted this thread to get a better insight on the type of oil needed. Before last wendsday i was counting on using just off the shelf 10w 30 but then someone said something about needing zinc, so I posted this. So sorry for the thread didn't think it was gonna go this far 0.o Anyhow Thanks for the input.
Reply 0
Jan 15, 2009 | 11:46 PM
Ya, I was gonna warn you about this can-o-worms in my first post lol
Is the engine built? Too late to change to a roller setup? It would be worth it IMO... alot less issues to deal with as far as oil and wear goes.
Reply 0
Jan 16, 2009 | 12:46 AM
Quote: As far as getting into zinc and ppm and all that stuff, I can say this: I have broken in countless engines in the past with nothing but off the shelf valvoline conventional oil.
Things changed with the introduction of GF-4 oils. Reduced ZDDP for the protection of sensitive emissions equipment have had a negative effect on older engines with flat tappet cams. Since the newer engines with the sensitive emissions equipment have roller lifters, it doesn't affect them.
It is something to be aware of if you are running a flat tappet cam, but it doesn't warrant the playground "Oh yeah?" stuff.
Reply 0
Jan 16, 2009 | 11:13 AM
Quote: Ya, I was gonna warn you about this can-o-worms in my first post lol
The engine is not build I'm gonna do that probably tonight and the only thing I haven't bought for it is the cam and headers, so I could go for a different cam but the guy helping me build it did a lot of research on this one as far as getting the right compression ratio for the cam and lift and all that jazz.
Reply 0
Jan 16, 2009 | 02:57 PM
Quote: Things changed with the introduction of GF-4 oils. Reduced ZDDP for the protection of sensitive emissions equipment have had a negative effect on older engines with flat tappet cams. Since the newer engines with the sensitive emissions equipment have roller lifters, it doesn't affect them.
I know what you are saying, and am familiar with the changes in oil. I was just pointing out that many people still break in engines without any additive at all and do not experience cam failure. I found it humorous that a simple question, with a simple answer of use xxx additive could degenerate so quickly.
Reply 0
Jan 16, 2009 | 03:38 PM
Also with that change from tappet to roller there was a price jump from 250 to like 700 so I think Ill stick with the tappet. All I got to say is parts are changeable.
Reply 0
Jan 17, 2009 | 04:18 AM
Quote: Also with that change from tappet to roller there was a price jump from 250 to like 700 so I think Ill stick with the tappet. All I got to say is parts are changeable.
Fair enough - it is a fairly expensive upgrade if its not a factory roller block. But if a cam lobe does go, thats ALOT of metal in your oil really quick, and can wipe out other stuff.
But as said, if you use the right oil, you'll more than likely be OK. I have a flat tappet XE274 cam in my 350, and I use 10-30 synthetic with a bottle of EOS (ask the GM parts guy for this stuff, its cheap... you want the 6/8 cylinder bottle) and I have never had a cam or valvetrain related problem yet. I broke it in with a bottle of EOS and 15-40 Diesel oil (non synthetic of course).
But you'll likely be OK if you use one of the recommended oils above - Five7 knows his stuff when it comes to engine oil IMO. He is an AMSOIL rep IIRC, but doesn't push it just to sell it, but because it actually is really good stuff. Its what I use in both my LT1 and my old 350.
Reply 0
Jan 21, 2009 | 03:39 PM
don't use the synthetic for the break in period. Not a good idea! Either Rotella 15 40 or use a designated breakin oil.
Reply 0
Jan 21, 2009 | 07:29 PM
"Extremely lubricating oil" I like that. It's like saying "Really hard Diamond" lol
Reply 0
Jan 21, 2009 | 10:42 PM
Sorry to keep beating this horse but...
Actually, the formula for rotella 15w40 has been changed too within the past year to a CJ rating. The levels are below 1200zddp. The rotella 30 single grade however does provide enough zddp for cam break and post breakin without additive.
I understand that some people may have broken in their cam fine without any additive or special oil however A LOT of people have been getting their cam lobes knocked off. Just do a search for it and you will see some horror stories. All because they failed to use an oil with enough zinc.
An additive would probobally work OK but not better than oil with the correct zddp blended in at the factory. On the safe side, I would run an oil with a tested zddp level of above 1300 and some extra break in lube. Delo 400 or Rotella 30 with a little eos or other zddp lube ought to do the trick nicely. Better be safe than sorry. Unless somebody can provide evidence to me that delo le has a zddp level below 1300, I stick to my story.
Reply 0
Jan 22, 2009 | 07:40 AM
Alright thanks. I probably hit up the parts store today and try to order some rotella, Whats the eos stand for though?
Reply 0
Jan 22, 2009 | 10:35 AM
Quote: I know what you are saying, and am familiar with the changes in oil. I was just pointing out that many people still break in engines without any additive at all and do not experience cam failure. I found it humorous that a simple question, with a simple answer of use xxx additive could degenerate so quickly.
It's kinda funny I use the cheapest oil i can find for break in. The only cam I ever had go bad was a COMP cam but that was long before they started dezinking oil. Hoestly I think people are geting a little too lash happy cranking the valves too tight re-grinding thier cams. It's just nice to pass the blame on to thier oil choice.
Reply 0
Jan 22, 2009 | 12:52 PM
Quote: Alright thanks. I probably hit up the parts store today and try to order some rotella, Whats the eos stand for though?
No problem. EOS sthads for Engine Oil Suppliment. It's made by GM but good luck getting it. I went to 3 different dealerships a few months ago and nobody had it in stock. You CAN get it online though. Basically, the crane lube, lucas lube, and eos are the best to use when breaking it in.
Reply 0
Jan 23, 2009 | 02:09 PM
Quote: No problem. EOS sthads for Engine Oil Suppliment. It's made by GM but good luck getting it. I went to 3 different dealerships a few months ago and nobody had it in stock. You CAN get it online though. Basically, the crane lube, lucas lube, and eos are the best to use when breaking it in.
For some reason GM decided its not for retial sale they may have it but some dealerships arent selling it to walk in customers.. Go figure.
Reply 0
Jan 23, 2009 | 02:32 PM
Well i just picked up 12 q of it about 5 mins ago, I mean i got rotella 30 and a bottle of crane additive to add zinc so does this sound right for the brake in?
Reply 0
Jan 24, 2009 | 12:55 AM
Quote: Well i just picked up 12 q of it about 5 mins ago, I mean i got rotella 30 and a bottle of crane additive to add zinc so does this sound right for the brake in?
Sounds good! You're set!
Reply 0
Subscribe
