TPI engine high revs at idle
Hi I have a 1991 RS Camaro which I have just fitted with TPI when i start it it goes streight to 3000 rpm I have checked for vacuam leaks and found none when I remove the vac line into the MAP sensor the revs drop to 1200 (probably through the ECM limp home mode)but then it starts to over fuel, I have checked the voltage in both the TPS and MAP sensors and both give the correct readings, where to from here Help
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
