Do you know what this is??
Old Jan 17, 2009 | 11:21 PM
storm's Avatar
Car: 89 IROC 5.7L AUTO
I found it tucked back behind the distributor, not bolted to the firewall or anything like it appears it should. There was a two wire connector hooked up to it on the bottom (couldn't see where they ran - back down towards the tranny somewhere) with 2 hard plastic vacuum line ports on top (one missing completely, the other you can see still connected in the pic, but one is broken off).
What is this?
Attached Thumbnails Do you know what this is??-img_0799.jpg   Do you know what this is??-img_0800.jpg
Old Jan 17, 2009 | 11:24 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Do you know what this is??
Looks like the EGR valve solenoid.
Old Jan 17, 2009 | 11:56 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Yep, that's what it is.
Old Jan 18, 2009 | 12:04 AM
storm's Avatar
Appreciate the ID, guys! Thanks! Where does it bolt up?
Old Jan 18, 2009 | 10:41 AM
jv9999's Avatar
Engine: 5.7L/350
It mounts under the coil. It has an electrical connector on it and two vacuum lines. I'm guessing a previous owner thought it would run better or produce more power without the EGR, but he was mistaken. This thread might help:
https://www.thirdgen.org/forums/tech...sor-where.html
