Internal/External Balance
Old Jan 19, 2009 | 01:25 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Last fall I finally got a 350 for my Camaro. It came with an automatic flexplate which I'm tossing for my T-5 flywheel. What I need to know is if I need to have the flywheel balanced or replace the damper due the engine being internal or external balance. Not sure if the flexplate on a 2 piece seal was ever part of the balancing. The casting on the block is 3970010 and to my knowledge, it's factory stock.
Old Jan 19, 2009 | 01:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Internal/External Balance
It's internally balanced, unless someone did something silly during a rebuild.
Old Jan 19, 2009 | 01:57 AM
84Z28406's Avatar
Ok, one less thing to worry about. So was it just the factory 400s that were external then?
Old Jan 19, 2009 | 02:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
For the 2 piece RMS era, yes.
Old Jan 20, 2009 | 11:53 PM
basiccamaro's Avatar
The newer, one- piece rear main seal 350 engines have a slight bit of weight spot welded on the flexplate because the crankshaft flywheel mounting face is a perfect circle. This not as much as the weight that you find attached to a 400 or 454 flywheel/flexplate.
On the older two- piece rear main seal engines the flywheel mounting face of the crankshaft has an offset, squarish portion hanging out radially, which provides just a touch of needed extra balance.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
