quick head gasket question
Old Jul 30, 2008 | 01:11 AM
1fastcamaro88's Avatar
Car: 1988 camaro sc
Engine: nasty 305 tbi,tba 632 big block
Transmission: built 700r4
ok ive contenplating on with gaskets on wanna run on my 305 tbi. i wanna increase the compression. im about to put on World s/r heads (67cc,171cc)but just couldnt decide any opinion would help!
heres a few im looking at:
http://store.summitracing.com/partde...=1#Application
http://store.summitracing.com/partde...3&autoview=sku
Old Jul 30, 2008 | 01:34 AM
HawkHunter's Avatar
Re: quick head gasket question
changing your headgasket makes such a small difference in compression ratio - a dyno would be hard pressed to notice a difference. What's your current compression ratio? Aluminum or Iron heads? Your best bet to increase compression ratio is to shave your heads, how much depends on a lot of things, like current valve clearance and dome/dished/flat-top pistons (piston to head clearance). Unless you currently have a .070" gasket or something silly, your butt-dyno wont even feel a difference in a 030" gasket difference.
going from .041 x 4.166 to a .015 x 4.1 gasket would do something like 8.316:1 to 8.858:1 - which is really next to nothing and would cost you a lot of money, because you have to do a lot of maching work to put in a shim gasket to the block and the heads. You're better off to shave your heads at that point. You should be aiming for closer to 9.5:1 to 10:1 compression ratio with iron heads (you'll have to fill up with premium gasoline). If you have aluminum heads you can aim for closer to 11:1 compression (again you'll have to run premium gasoline).
This assumes everything else is ready for the increased compression - ie. good strong block and you're getting a new head bolt set right?
cheers
Old Jul 30, 2008 | 10:36 AM
EvilCartman's Avatar
Car: '82 Z28
Well that's strange... I switched from some thick **** victor headgasket to a .015 shim gasket and noticed an improvement. Engine has a bit more pop and I started running high 11's. Oh yeah, didn't have any extra machining done. Just popped the heads off, cleaned up everything and put the shim gaskets in. Been in there over a year now without problems.
Old Jul 30, 2008 | 03:21 PM
Car: 1988 camaro sc
the heads are iron i do have new head bolts to go on the pistons are stock flat top rite now the block is in good shap the current compression is around 9.3 or so
Old Jan 21, 2009 | 02:48 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
I hate to grave dig but it beats starting a new thread for a simple question. You say you didn't need any machine work to throw shim gaskets on. Would I be able to use them without machining if its a stock block never been touched and brand new aluminum heads?
Old Jan 21, 2009 | 02:58 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Would be fine. Just make sure the deck is square.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
