Stalling after full throttle or burnout
Old Jan 19, 2009 | 11:21 PM
VEGASIROC's Avatar
Transmission: Manual
Hello,
I have a 90 IROC with a 305 TPI and manual trans. Every time I give it full throttle or do a burnout the motor stalls. I have to give it about half throttle while cranking to get it started again. Runs fine after that. Any ideas would be appreciated.
Old Jan 20, 2009 | 03:31 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: Stalling after full throttle or burnout
Just a wild theory; check your oil pressure to be on the safe side. I dunno for sure if it would behave like that with low pressure, but maybe some bearings get in contact with each other when under heavy load.
I had a small carbed 4-cyl car once that struggled keeping alive after heavy loads at low revs. It would later develop rod knock and get even lower oil press.
Of course your problem might be related to the FI needing a tune-up.
Old Jan 20, 2009 | 03:35 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
check your o2 sensor, my car was doing this when the o2 sensor wasn't screwed in very tight, i tightened it up, now it runs perfect
Old Jan 20, 2009 | 04:08 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I'd be more likely to lean towards cleaning your IAC.
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
FreeSpirit
Aug 29, 2015 05:47 PM
GVMV
Aug 16, 2015 08:01 PM
novaderrik
Aug 10, 2015 12:44 PM
