Car starts, but wont move....
Old Jan 20, 2009 | 10:36 AM
Matt Bane's Avatar
Car: 1986 Pontic Firebird
Engine: 2.8L V6
Transmission: auto
I've got a 1986 pontiac Firebird, automatic 2.4L V6. I'm able to start it up and it sounds great, but unfortunately when I shift it from park to Drive, and give it gas, the engine only revs. I was wondering if anyone could give me an idea as to what it possibly could be, if you need anymore information, just post what you need to know, I dont know much about cars, sorry. One thing ive noticed (dont know if it will help or not) is that when it is in park, I cant push it anywhere, I have to move it to neutral or drive to be able to move it, so it seems like its shifting in some ways. Any input would be greatly appreciated. Thank you
Old Jan 20, 2009 | 10:57 AM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: Car starts, but wont move....
I'd check your fluid level in the transmission check linkages and then if still nothing your transmission is probably burned up the car wont move in park because park locks the drive shaft locking the rear wheels, good luck man
Old Jan 20, 2009 | 11:10 AM
Matt Bane's Avatar
Engine: 2.8L V6
Transmission: auto
If my transmission is burned up, any ideas how much that would cost to fix? It would break my heart to have to sell this car, but I doubt id be able to afford to fix it. Also, how much do you guys think I'd be able to sell the car for with a burned up transmission?
Old Jan 20, 2009 | 11:15 AM
mario82z28's Avatar
I don't know every transmission shop seems to charge something different it cost me 1,200 but I got a lot of extra goodies put in mine but that was also me taking the transmission out of the car and putting it in your best bet might be is a used one somewhere just look around I'm sure someone on here got one for sale
Old Jan 20, 2009 | 04:11 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
A standard rebuild on a 700 is anywhere from 500 - 700 bones.
Old Jan 20, 2009 | 06:36 PM
rodrob1961's Avatar
Car: 2003 SILVERADO /86 IROC/85 S10
Before writing off the tranny, I'd change the fluid and filter. Then, if it still acts up, I'd decide whether or not to keep it.
Old Jan 21, 2009 | 01:19 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
2.4L V6
But, Check the shifter cable, before I knew much about cars, I had my 91 rs towed home, and after a week or so, we realized the shifter cable end broke, and caused it to slip off of the tranny, Maybe yours came undone a bit and is causing it to not fully engage drive.
-Bradley
Old Jan 21, 2009 | 03:49 PM
50bmgshooter's Avatar
-Bradley
if this was the prob it wouldnt release from park
also if you have tried to move the car too much or if the tranny has bin driven with very low oil you can kiss it good by. sorry to say that. also check your drive shaft. u joint might be broken or someone might have snagged it. have seen that happen a couple of times
Old Jan 23, 2009 | 08:30 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Most likely the trans is shot, and there is no point in doing a service...won't help. As for the value, virtually none. 4 banger birds with blown trannies just aren't desired. Sorry to be the barer of bad news... no point in beating around the bush.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
L98GTA87
Aug 5, 2015 11:02 PM
