86 TA timing slip
Old Jan 20, 2009 | 11:42 AM
tdtommy89's Avatar
86 TA timing slip
I have an 86 Trans am with a 305 TPI engine with what we think is a timing slip. It will start but wont stay running. It happened when we were putting an alternator on it. He pulled a fuse to check for the turn signal fuse as well. It was running like it never ran before then it just crocked over. What tools and parts would i need to fix the timing slip? what amount of $$ am i looking at here? ballpark
Old Jan 20, 2009 | 11:55 AM
tdtommy89's Avatar
Re: 86 TA timing slip
It started acting up after the pulled fuse
Old Jan 21, 2009 | 03:14 PM
blp226's Avatar
Use a test light and see if your distributor is getting fire the entire time, it may only be getting juice when the key is in the "crank" position and not in the "run" position. If its not and your fuses are good it could be a fusable link. Or maybe a bad ignition switch or a wire in the steering column. It's worth a check anyway.
Street Lethal
Apr 30, 2019 12:14 PM
maroe624
Apr 16, 2017 08:29 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
