Smogged and failed w/flying colors
Old Jan 20, 2009 | 06:27 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
So When i first bought the car it passed with flying colors. This was back when the 350 was running on everything from the 305 that was in there before.
Today i had to smog it again but failed the unburnt HC at idle.
Supposed to be maximum of 120 and considered to be a Gross Pollutor after 270, it measured at 518...
I just made the appointment and went right in no running "Garunteed to Pass" through just went to the station and sat back.
Some things it might be caused by:
--Fuel pressure set to 50 PSI
--Throttle Body Airfoil from TPiS
--I am using the 305 .bin file with the 350 SA tables(with this one i think i will either tweak with the sa tables or just go back the the original AXYC bin and try it out)
--Intake from GT Fiberglass
Before you ask, here is a list of things that i have done to my car.
-Edelbrock intake manifold and runners
-Edelbrock Headers
-BBK AFPR
-Bosch III injectors 22#/hr
-MSD ignition box, coil, plugs, wires, cap, rotor, fuel filter, ignition control module.
Any ideas whatsoever? Any obvious fail culprits?
Old Jan 20, 2009 | 07:58 PM
grungera91Z's Avatar
Car: 91 Z28 t/top
Re: Smogged and failed w/flying colors
I assume you tested it warm/hot. How old is your cat converter? My 91 has always been unpredictable when it came to smog tests, even in good running order. Any time I failed I replaced my cat each time and passed no problem. I finally made it through 2 checks with 1 cat converter and solid measures (although I have kept the mileage low the last 2 years).
Old Jan 23, 2009 | 11:13 AM
boldguy's Avatar
Car: 1992 Z28
If it never went into closed loop, or if it went back into open loop from just sitting there idleing, this would cause the Idle HC's to be a high level no? I lowered the fuel pressure and changed the SA tables back to stock (305 cid AXYC BCC) and the injector flow rate to 19.something and the cyl vol to 713.0cc. I think i will drive it a while and let her warm up real nice and then take another swing at it...
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Nervous2
Oct 8, 2015 10:53 PM
Linson
Sep 21, 2015 01:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
angel2794
Sep 8, 2015 06:22 PM
