need quick help
Old Jan 21, 2009 | 09:13 AM
racerquinny's Avatar
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
need quick help
i just returned from school. i noticed oli pressure gauge is all the way past 60psi. it wont budge, i checked my oil it was low. i put some oil in it and let it run for about 2-3 mins. the gauge didnt budge. so i need some answers in liek an hour before i head of to school vo-tech.
i got a 91 camaro. 305 tbi. if that helps.
Old Jan 21, 2009 | 10:09 AM
50bmgshooter's Avatar
Re: need quick help
my 91 rs did that. it was a bad oil pressure sender
Old Jan 21, 2009 | 11:10 AM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Re: need quick help
yep, change oil pressure sender. Its on the rear of the engine by the fire wall just to the drivers side of the distributer.
Old Jan 21, 2009 | 02:30 PM
Re: need quick help
ok thnank you i will do that. will that affect my engine at all untill i change my oil in about 1300 miles. thank you i was worried if my car was going to blow, but i think thats when you get no oil pressure hahaha
Old Jan 21, 2009 | 02:49 PM
Re: need quick help
is it also called oil pressure switch?
Old Jan 21, 2009 | 03:43 PM
Re: need quick help
no if its the switch it wont cause a prob. but you dont need to drop your oil to change the switch just unplug, unscrew, screw in and plug in then check your psi gauge
Old Jan 21, 2009 | 05:48 PM
Re: need quick help
how much do those run in price, for the sender.
Old Jan 21, 2009 | 06:03 PM
Re: need quick help
forget how much mine was but onlt like 10 or 15 $ from advanced
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
