89 bird tpi Injectors not firing
Old Jan 23, 2009 | 12:33 PM
tjlandrover's Avatar
89 firebird tuned port..good fuel pressure to rail, cranks, Sparks, , I thought the vats might be it but the security light is out when you crank, any help would be greatly appreciated..Tony
Old Jan 23, 2009 | 02:32 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: 89 bird tpi Injectors not firing
Get a DVM and see if you are getting steady +12 volts on one side of injector connector and pulsing on the other . If there is no +12 volts injectors will not fire...
//RF
1992rs/ss
Jan 31, 2025 05:10 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
mdtoren
Aug 23, 2015 12:52 PM
Sanjay
Aug 12, 2015 03:41 PM
