RMS leak
Old Jan 23, 2009 | 01:58 PM
JPhillis's Avatar
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
RMS leak
I have found I have a rms leak. I have the engine out now and found at some point some one has replaced the rear main seal. It appears that instead of dropping the pan and removing the rear seal housing to replace it they used a seal pic. There was a scratch in the seal surface on the crankshaft. I very very carefully used some 600 emery cloth to clean it up. If this does not work does anyone know if they make a ready sleave for the 1piece rear main seal type crankshafts????
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
