check engine light
Car: 1992 Camaro
Engine: 5.7 L 350 V8
check engine light
chevy camaro
1992
v8 350
so my check engine light has been coming on lately, not every time I drive, just maybe 50% or so. I just had my oil changed this week so I know its not that. Any suggestions?
also, a while back, within a year ago, i had my transmission rebuilt. My car seems to lose power in the lower gears. when i jump on the gas, i dont accelerate like i should... having jsut replaced my tranny not too long ago, I dont think it is related to that. Maybe my chip?
any help would be greatly appreciated.
1992
v8 350
Car: 86 T/A
Engine: 5.0 TPI
Re: check engine light
Your computer is sensing a problem. It could be just about anything. It's probably something simple like your O2 sensor or something.
Car: 1992 Camaro
is it something I can check myself?
i dont have a bunch of money lying around to take it to a shop...
any insight to how I could check on it myself?
Car: 86 T/A
Engine: 5.0 TPI
You can do it yourself but I'm afraid I can't explain how. You have to jump 2 wires in the connector under the dash, where they hook into the computer, and then the check engine light will flash out a code. Then you have to find out what the code means. Good luck.
did a search ... go here. https://www.thirdgen.org/service-eng...ht-error-codes
Car: 1992 Camaro
haha thanks, i just read that. so ill try that i guess. then once i figure out whats wrong ill decide whether to bring it to a shop or try and fix it myself. thanks for your help
