IDLE is out of control
Old Jan 27, 2009 | 01:32 AM
moneyman380's Avatar
Car: 1991 Z28
First let me start off with the engine 355 tpi in a 91 z28 Mods: superram, aftermarket heads, cam, 58mm tb, adjustable fpr, larger injectors, roller rockers, headers
The problem is the idle surges in park and neutral, dies in drive or any gear unless you work the gas, idle high and cant seem to set IAC and when i manage to or as close as i can it wont start unless you treat it like an old carbd truck working the gas pedal. Sometimes you even have to hold itat a high rpm for a minute to keep it running or to warm it up.
Also i have a prom programer and all the other tools needed to burn chips and i do use them in my car so if its programming i can change it just dont know what if anything needs to be changed in the prom or if its wiring or a sensor or part.
Here is what i have replaced since this started
ignition module
distributor
ignition coil
knock sensor
map sensor
every sensor and servo on my car has been replaced within the last two years
Im am completely stumped as to what this could be Any ideas?
Old Jan 27, 2009 | 02:53 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: IDLE is out of control
How large are "larger injectors"?
What is the fuel pressure regulator set at?
Old Jan 28, 2009 | 01:35 PM
Car: 1991 Z28
They are 25 lb injectors and the fuel pressure was ok last time i checked it i just havent been able to since this problem started. My fuel pressure gauge is broke so i will pick one up tonight and post the readings.
Old Jan 28, 2009 | 02:32 PM
Car: 1991 Z28
Ok just checked the fuel pressure it roams around 40psi at a high idle but varies from 38- 42psi . I plugged the laptop in and it looks like the tps is working fine but the iac is going from 80-220 up and down with the surging. It making me a litttle worried . Im still stumped
eightsixseven
Dec 16, 2024 01:50 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike40sm2
Sep 1, 2015 02:15 AM
Dialed_In
Aug 20, 2015 01:45 PM
