L98 starter?? Lt1 mini?
Old Jan 27, 2009 | 10:09 AM
BlKnt18's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 L98 Carb. Alum. Heads
Axle/Gears: 3.08 Limited Slip
Ok so I just bought an 89 iroc and it has a l98 swapped into it that is carb'd with a build t-5 tranny. It started up fine and has been except for a bad battery I just changed but then today it started then died because it was cold. I went to start again and it just grinds like the starter isn't engaging. I haven't got under it so idk if it is bad starter or bad teeth on the starter or flywheel, but if it is the start I want to put on the lt1 mini starter. I have shorty headers and the old owner has some heat wrap around the old starter so I'm guessing this one may get hot and I thought the mini would be better. Also I am running 11.5/1 comp so I think I need to make sure the starter to stand up to that?? Thanks
WejaZ28
Oct 3, 2015 07:38 PM
sahlomonic
Sep 20, 2015 07:15 PM
Magman
Sep 13, 2015 12:07 AM
09ave
Sep 7, 2015 06:03 PM
Formula_88AE
Sep 3, 2015 01:47 PM
