LT1 cam and valve train compatible with gen 1 roller block?
LT1 cam and valve train compatible with gen 1 roller block? My brother paid $400 for a 89 Iroc 350 engine that someone had converted to a hydro flat tappet. Damn thing spun a bearing a month after we put in his Nova. I've got ready to reassembly and now he's decided to go back to a hydro roller except I've got no retainer, dog bones, or roller lifters. Someone has all the valvetrain for sale from an LT1. Just curious if they're interchangeable. Thanks in advance. Also what are the specs on a stock LT-1 cam?
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: LT1 cam and valve train compatible with gen 1 roller block?
yes it will interchange no problem.. don't pay too much for these parts they are plentifull
Engine Valve Lift @ .050"(1.3mm) Specification Engine Lobe Lift @ .050"(1.3mm) Specification
LT1 Intake .447"(11.35mm) LT1 Intake .298"(7.57mm)
Exhaust .459"(11.66mm) Exhaust .306"(7.77mm)
Engine Duration @ .050"(1.27mm) Specification Engine Lobe Separation Specification
LT1 Intake 205 deg. LT1 117 deg.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You'll have to shorten the dowel pin, either by cut off, or hammer it in further. Roughly 5/16" is what you're after. Any length is alright, just so long as it's fairly flush with the timing gear, can't stick past it.
Also, don't know what your setup is, but LTx cams don't have fuel pump eccentrics. If you have an electronic FP, then this is a non-issue.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
All the LT1 valvetrain stuff is compatible with the Gen 1, as long as its a factory roller block ('87+). The only exception is the timing set.
350, block, cam, camshaft, engine, gen, gen1, generation, interchage, interchange, interchangeable, lt, lt1, roller, setup, valvetrain
