Engine knock then coolant found in oil.
Old Jan 27, 2009 | 08:50 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
I am looking into a newly rebuilt engine that has a knocking sound. The valve train was worked with and the knock never left. The engine then came out of the car again and I am taking it apart to find the problem.
I found gray sludge in the engine and in the bottom of the oil pan along with some coolant in the oil. I found no problems with the new crank, rods, pistons, or bearings so far. One cylinder had a clean appearance in the chamber and in the ports around the valves. The other 7 showed some black sooting which I believe is normal. The head gasket showed no sign of failure.
Can there be a single problem causing the knock and allowing coolant into the oil?
Old Jan 27, 2009 | 10:31 PM
toomany's Avatar
Re: Engine knock then coolant found in oil.
There is water getting in somewhere. Intake gasket, head gasket, cracked intake or cracked head. The water/coolant will leave the chamber clean.
If your're hearing a knocking sound, then chances are it's a bearing. I'd bust out the mic's and check the journals (although a flattend bearing isn't hard to miss).
Old Jan 28, 2009 | 10:59 AM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
You would say the two are not related?
Old Jan 28, 2009 | 02:19 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
could be knocking from piston slap, or just cause the cylinder with the water isnt firing, and its a dead miss. did the engine over heat?
Old Jan 28, 2009 | 04:42 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
The heads and block are out of different cars. Each were parts cars and overheating could have happened. The heads and block were in the machine shop prior to assembly. If there is a problem with those items, they could have been missed at the shop.
I have not pulled the pistons or the crank. I pulled one main cap at a time to look for trouble. I then did the rod bearings. Nothing unusual. Piston skirts and walls check out good. Only leaves the rings in the short block. I've had no reason to this point to think anything with the cam or timing set.
Coolant on a piston can make that consistant knocking/ticking noise?
Old Jan 28, 2009 | 05:09 PM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
If there was only a little anti-freeze in the oil it probally
came from pulling the heads.
A picture is worth a ga-zillion words so post a picture of
the head that has the "clean appearance in the chamber
and in the ports around the valves"
Old Jan 28, 2009 | 06:23 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Coolant was found in the oil before anything was taken apart. Oil drain was first. Also found gray sludge, assumed it was part of the coolant in oil issue.
db057
Aug 22, 2015 08:17 PM
bjpotter
Aug 12, 2015 06:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
antares57
Aug 6, 2015 07:47 AM
