350 Full Gasket set question?
I'm doing 2 engine rebuilds at once right now. One for my street strip car and the other for my brothers Nova.
My setup is a 80' 350 4 bolt main and the other is an 89' 350 2 bolt roller engine. Both will be carbed. What would be the difference in these 2 gasket sets kits besides the rear main seal? The early model gasket set is much cheaper than the late model. Just wondering if I can buy early model gasket sets for both and get the 1 piece rear seal separate?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: 350 Full Gasket set question?
And the valve cover gaskets-providing you're going back with center bolt heads on the late engine. The earlier set should have perimeter bolt gaskets, probably cork.
Transmission: 4L80E/4L80E
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
