View Poll Results: what do I do?
run the motor even with the low compression
66.67%
re-ring the non roller motor
33.33%
swap pistons and spend $500
0%
buy a cheap old DD truck and build a better motor.
0%
Voters: 3. You may not vote on this poll
engine opinions please.
Old Jan 29, 2009 | 07:08 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
ok, here is my problem, I have a 350 that I could put together and have running, but comp recommend I run at least 9.5:1 compression with my ca, and this motor would be about 8.5:1 even with thin headgaskets and 64cc heads.
I have another 350 that ran fine when I pulled it, but has a little bit of surface rust in the barrels from sitting(dam florida air!), I could re-ring it and use it, but then I would have thrown $300 out with the cam I bought. (non roller block)
Yes, I could swap the pistons in the first motor for flat-tops, between balancing andnew pistons, rings, and balancing it would cost me about $500.
last idea, buy a $500 S-10 or somethingas a daily driver and save up and build the motor to spec.
Old Jan 29, 2009 | 07:12 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
re: engine opinions please.
Are you sure you would only have 8.5 to 1 with thin gaskets and 64 cc heads?
Old Jan 29, 2009 | 07:15 PM
ericjon262's Avatar
yea, deep dishes w/ valve reliefs, I've crunched the #'s a couple of times. 8.5:1, not ideal for a performance motor unless you strapping a blower to it, but with a cast crank, pistons, ad factory rods, no thank you
camaro71633
Sep 1, 2015 10:24 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
