a couple of questions
Old 01-31-2009, 02:23 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
i am ready to start building my 355, and i have a few questions conserning general engine stuff.....
1: i have heard it said that a large cc chamber will outflow a small cc chamber because it unshrouds the valves, is this true? i have a set of afr 195 eliminators, 1038 75cc chamber, with the pistons i am choosing should yeild a 9.2 to 9.3:1 compression...
2: would it hurt to assemble the engine and sit it in the car without starting it for several months? or should i wait?
thanks! adam
Old 01-31-2009, 08:53 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: a couple of questions
Haven't heard about your unshrouding the valves thing but it will not hurt your engine to let it sit for several months. If you assemble it properly with the assembly lube and oil up what you're supposed to during assembly you'll be fine.
Frozer!!!
01-19-2024 04:55 PM
chazman
08-28-2018 03:25 PM
Cleotiz
01-06-2018 08:56 PM
ezobens
08-19-2015 10:29 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: a couple of questions
