Engine Revving Self Up
Old Feb 1, 2009 | 10:12 PM
kpop's Avatar
Help! My 92 Camaro RS has been revving on its own!
It does it all the time; while I'm at a stop light, trying to brake,
even when I'm coasting down the road.
Last night when pulling into a parking space, my car revved itself
up and I almost hit the car next to me...I'm stumped.
Has this happened to anyone else?
Old Feb 1, 2009 | 10:29 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Engine Revving Self Up
Check speed sensor singnal to ECM. Also check TPS.
Old Feb 1, 2009 | 11:10 PM
toomany's Avatar
I'd look for vacuum leaks. Start the car and spray some carb clean onto the vacuum lines, intake gaskets, power brake line. Could also have a leak in the brake booster.
Old Feb 1, 2009 | 11:12 PM
kpop's Avatar
Is there any easy way to troubleshoot or should I just go ahead and replace the sensors?
I only know how to fix what's broken in the past, so each time is a brand
new learning experience.
Thanks for your help!
Old Feb 3, 2009 | 03:25 PM
87cam's Avatar
Car: 1987 Sport Coupe
Just try replacing the TPS. It is only around $30 and it takes 2 seconds.
Old Feb 3, 2009 | 04:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Before you go replacing things, is your SES light coming on?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
