How to set engine idle screw
Old Feb 4, 2009 | 05:43 PM
dickeymoore's Avatar
I have a 1987 Iroc with a TPI 5.7 engine and was wondering how to set the engine idle,it looks like the screw is covered in the back with a small round plate or something,any help?THANKS
Old Feb 5, 2009 | 02:44 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: How to set engine idle screw
https://www.thirdgen.org/tpimod2
Old Feb 5, 2009 | 03:52 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Just punch through it with a phillips/flat head and pry it out and discard. The screw is located underneath.
Old Feb 5, 2009 | 06:10 PM
OK THANKS
Old Feb 5, 2009 | 09:00 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Originally Posted by dickeymoore
OK THANKS
But that's NOT how to set the idle. Read the link above.
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
camaro71633
Sep 1, 2015 10:24 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
