car dosnt want to move
Old Feb 6, 2009 | 12:14 PM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
As dum as this sounds I cant get my car to move… got laid off and now I have absolutely nothing to do, so I decided I would push the car out of the garage to admire it… sooo I start to push nothing happens, so I get under the car and put the tranny in neutral (don’t have the cable hooked up). Get back up and start to push, still nothing… then I realize hey I don’t even have the drive shaft in wtf is going on…. E brake is down, and I don’t see any reason that the brakes would lock up on me… anyone have a clue?
Old Feb 6, 2009 | 12:43 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: car dosnt want to move
Assuming the parking brake actually released the brake rusy brakes will do it for sure if it hasnt been moved in a while also the tires may have a flat spot from sitting.
Old Feb 6, 2009 | 12:46 PM
burn0ut305's Avatar
Car: z28
u kno i could just jake the back end up and try to spin the tires... that sould give me a lil more insite on wuts going on...
Old Feb 6, 2009 | 12:54 PM
burn0ut305's Avatar
Car: z28
Ok sooo passenger rear will only spin forward… but drivers rear spins both ways…. somthing locked up wut is it?
Old Feb 7, 2009 | 11:09 AM
The brakes just locked up. It may be due to rust forming it may be due to the ebrake cable not releasing all the way but it has something to do with the brake. Actually when you set the e brake you you do it is pull the ebrake up a few clicks and adjust the cable till it will only rotate in one direction.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
AkDrifted
Aug 17, 2015 07:45 PM
novaderrik
Aug 10, 2015 12:44 PM
